    Oct 2003
    Nevada
    I have a damaged DVD that DVD decrypter was not able to extract. I also tried Nero and NTI to try to create iso images from but due to defects in the DVD they also failed. I have obtained a VCD of the same video and would like to convert or produce an mpg file which I could then process with an authoring program such as DVD Author or directly a new DVD of this material.
    I have been unable to figure out the tools that could be used to accomplish this task. If there is a way to solve this problem could someone please either point me in the direction or point me towards a guide that I could follow to solve this problem.
    Thanks,
    plipton
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Try this one: https://www.videohelp.com/guides.php?link=522
    Or any of the others in the Convert to DVD category
    Google is your Friend
  3. Finding software to do it is'nt a problem just finding 1 thats free, I tried the cucusoft encoder which gave a free trial and TMPGEnc, both gave good results but cucusoft would only do a very small file and TMPGEnc was a time limited demo, cucusoft was v/easy to use but lacked any setting changes so I ended up getting TMPGEnc 2.5 which I like (once I know how to use it properly ) and it gets good reviews of ppl who know
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I can't say that I've ever heard of a freeware MPEG-2 encoder.
    If in doubt, Google it.
  5. QuEnc, it rules, and its FREE! The quality is good, speed is ok.
  6. If you have a VCD then you do not need to convert or re-encode the video. VCDs are in a DVD-legal resolution.
    Here is the link (found under Author guides):
    https://www.videohelp.com/guides.php?guideid=533&howtoselect=3;29#533
    Hope this helps,
    Cobra
    Oct 2003
    Nevada
    Thanks got all of the data reconverted to a dvd.
    Does anyone know how to get Ulead output dvd movie files to get processed by dvdshrink?
    plipton
  8. Member teegee420's Avatar
    Dec 2003
    Southern California
    Author the DVD as normal in Ulead, then point DVD Shrink to the VIDEO_TS folder on your hard drive. That's it.
