Hi,
I've captured some video from a VHS source at 768x576 with Huffyuv compression in VirtualDub (using a PCTV Rave card and the btwincap capture drivers). I now wish to prepare the video for burning on to a DVD with optimum quality.
My many questions are:
1) Was this the correct resolution to capture at?
2) So far I have not ran any de-interlacing (or any other) filters - is this OK?
3) I want to crop the video to remove the black borders and the usual bad sections at the bottom of the VHS capture. I need to crop:
11 pixels from the left side, 4 from the right side (X1, X2 offset)
0 or 1 pixel from the top and 27 pixels from the bottom (Y1, Y2 offset)
at this resolution.
Should I crop more so that the video dimensions are multiples of 16?
4) Should I resize the video horizontally at any point seeing as it is interlaced?
5) I realise that I will probably need to use another program at this point such as AviSynth or TMPGenc (with which I am unfamiliar). My video will also be some strange resolution. Do these programs add in black borders around the video to pad it out to a standard resolution? If so how does this affect the resulting MPEG-2 file?
I realise that some of these questions will answer or change the context of some of the other questions, so sorry about that!
If you've got this far, thanks!
Regards,
Shane
Results 1 to 12 of 12
I should probably add that I don't want to distort the video, so a ratio of 4:3 is probably what I want. The video is in PAL format.
I've had a stab at this myself. Please let me know if/where I'm going wrong.
1) I cropped the video from 768x576 to 704x544 and resized to 352x544 in VirtualDub.
2) I ran TMPGenc with the Project Wizard and chose a DVD project: DVD -> PAL with CBR, Linear PCM Audio
Expert settings for source
video type: Interlace
Field order: Bottom field first (field B)
Aspect Ratio 1:1 (VGA)
No clipping - I already cropped in VirtualDub - was this right?
Other Settings:
Video settings: CBR at 8000kbits/s
Encode mode: Interlace
Advanced settings - Video arrange Method: Center (custom size) 352x544
Bitrate setting:
Video resolution 352x576 (autoselect picked 720x576) -
My guess would be to capture at a lower resolution which is closer to the VHS spec.
Have a look at this guide here: http://www.tomshardware.com/video/20030530/index.htmlGoogle is your Friend -
I agree with Krispy Kritter. Capture at a lower resolution. In many tests I have discovered that capturing too high can actually cause more artifacting issues while capturing at 352x480 (1/2 D1 NTSC) produces perfect video.
VHS is already a lower resolution than 1/2 D1, so raising the resolution and bitrate just adds more time that you'll have to waste re-encoding it. -
I always capture at 720X480/576 avi and then encode at 352x480/576,i found capturing at 352X480/576 and then encoding at 352X480/576 didnt have as good sharpness and details.
I have tried many capture programs and I don't bother with AVI files at all. I capture straight to 352x480 VOBs and don't have to convert. I used to capture at full resolution, but it produced quite a bit of pixelation, which doesn't happen at 352x480. With better sources than VHS, 720x480 does produce great results.
I agree. 352x480 has always produced great results for me.Originally Posted by Matt D
Matt D, what program do you use to capture to VOBs? The software with my card (Pinnacle PCTV-Rave) is buggy and gives very bad results so I'm using VirtualDub instead.
The reason I capture with VirtualDub is so I can remove the noisy bit at the bottom of the VHS picture as well as the black borders. Then I recentre the cropped picture in Half D1 size using TMPGenc.
Also, I've read somewhere on the site (https://www.videohelp.com/forum/viewtopic.php?t=221448) that Huffyuv uses the YUYV/YUY2 colourspace but TMPGenc uses the RGB colourspace, so I should be using another program instead of TMPGenc (or else capturing to 24-bit RGB?)
Is it worth buying TMPGEnc Plus 2.5 or TMPGEnc 3.0 XPress?
Thanks for all the help so far. -
It probably isn't necessary to crop anything because of TV overscanning.Originally Posted by Rooster667
Would the extra noisy bits not waste bandwidth though (or is the quality so low that it's not an issue with half D1 bitrates)?
I can't answer that definitively but I'm inclined to believe the latter.
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Confused ~~ Capture FIOS HDTV??
By Ghost2099 in forum Capturing and VCRReplies: 7Last Post: 17th Sep 2010, 10:26 -
Capture...convert...confused!!!
By cyber-junkie in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2010, 14:11 -
Confused about capturing VHS source to PC
By nomad2224 in forum Newbie / General discussionsReplies: 21Last Post: 13th Sep 2009, 14:43 -
new...confused..how to capture from dvd to dv
By ldubb619 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 16:22
