  1. Why does my program do that? I load an .avi file into the program, choose svcd as output and it creates a .mpg file. What am I supposed to do with that file?
    Also, do you guys know of an avi to svcd converter full version? or trial with a crack or something..
    Thank you so much, Ottosen
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    This isn't the place to be asking that, dumbass.
    If you want to make your SVCD, open Nero and select the SVCD compilation. Drop the mpeg into the compilation and burn away, so long as the mpeg fits on your disc.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It is doing what you wanted it to do. VCD's and SVCD's are mpeg format.
    Google is your Friend
  4. Yeah well..the mpg ends up being like 1.2 gb while the xvid version was 700 mb..Dunno what to do anymore really..
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Split the movie in half with this and burn them to seperate CD's. If you have any more questions you should start reading. There are lots of guides on this site.
    Dec 2002
    My Swamp
    Make sure you have a comfy chair , then do some reading.
    Start here https://www.videohelp.com/forum/userguides/94288.php
