  1. Please help,
    I have a nec-nd1300a and I have updated the firmware but the drive wont recognise the discs ive just bought (Silver Shadow Multimedia dvd+r)
    Please can someone help me.
  2. try buying quality media next time. 100-pak of ProDisc DVD-R at rima.com and supermediastore.com is $44 (plus tax and or shipping). I have a 1300 too and they burn, test, play fine. BTW what is the brand name of your dvdrs, and more importantly what is its media ID?
  3. The only info on the discs is Silver Shadow Multimedia dvd+r, I think they are Spanish made.
  4. Member 888888's Avatar
    Jan 2004
    Turdistan
    I don't think they make DVDRs in Spain. Probably packaged there. Check the media code with DVDInfoPro. Then check the NEC compatiblity list. Upgrade to latest firmware. And if all else fails, sell the discs on eBay at a dime a coaster.
  5. This is the info from the prog you mentioned
    Region information N/A not a DVD-VIDEO
    Manufacturer ID cannot be read
    Format Capacity Not Formatted
    Free Blocks 405405696
    Free Capacity 4.38GB(4.70GB)
    Book Type Unknown
    Media Type DVD+R
    Default DVD+RW book type DVD-RW
    Default DVD+R book type DVD-ROM
    Media Id Code Speed Unknown
    Available Write Descriptor CLV 2.4x 3324KBps
    Linear Density Blank Disc
    Track Density Unknown
    Number of Layers 1
    Does this mean anything?
  6. Member 888888's Avatar
    Jan 2004
    Turdistan
    Your disc does not seem to have a media code. This reflects pretty badly on them since this means they are super-generic, not even crappy Princo or CMC. Either that or there is something wrong with how your drive reads the media code on any DVD+R. If I were you, I would try out a few other brands of DVD+Rs and see if they work. Get a couple of good discs like ones with "Ricohjpn" media code and see if your drive recognizes and writes well on those. If it works with other media, I would just get rid of these "Shadow" discs, they sound like crappy media.
