Question - I have recorded some movies off satellite directly into MPEG2 using an ATI capture card. The problem is sometimes a 4.2 - 4.3 GB files fits on a DVD-R disk and sometimes it does not... I am using Showbiz to burn the file to DVD-R. Any ideas.? I thought a DVD was 4.7G?? How do I shrink the existing files and keep this from happening again?
thanks,
Jack
Results 1 to 10 of 10
Age old problem. This applies to Hard drives as well.
Media manufactures specify 1 kilo byte as 1000 bytes.
Computers are binary machines so 1 KB should be 1042 bytes.
So a DVD-R will write 4.7Gb (decimal system) or 4.3 using binary.
So you only really get 4.3 and you're right on the bondaries with your files, which are correctly reported assuming 1k as 1024 bytes.
Take a look at you 120Gb HDD, it will not be reported as 120 by the Opsys. -
It's the difference between a traditional computer Gigabyte and the 'new and improved' Gigabyte.
DVD Shrink will take care of the problem. It will bring the file down to the correct size if you're overbudget.
Actually, it's a completely different story for HDD, much older than the DVD thing. Advertised HDD capacity is a raw unformatted number of "real" 1024-based gigabytes. The useful capacity is less than advertised due to the overhead for the sector headers, checksum, etc. that's applied during the physical formatting of the HDD. Those who used to have the first MFM HDD models, which required physical formatting, must remember this.Originally Posted by tim6661234
At least checking a file's properties now will yield a number in binary kilobytes, and a number in bytes, so all it takes is a right-click to see if it'll fit on a DVD.
not enough room
By agent222 in forum Video ConversionReplies: 3Last Post: 9th Apr 2011, 12:16 -
After using DVD-RB, is there enough room to make DVD menus?
By sldvd in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 23:23 -
connect pc to another room monitor
By blader18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Sep 2009, 15:19 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Chat Room Required
By Ryudo in forum Off topicReplies: 3Last Post: 21st Jun 2007, 08:35
