have bin/cue problem Ijust started using this and I get the video but no sound am I doing something wrong or is it the file itself
You need to give more info. What did you do to get it playing and what are you using to play it with?
used winrar to get bin then bintoiso to get cue followed it up by using vcd gear 355 which gave me the mpeg also used windows media player to view
Hmmm. That's pretty strange. Try playing the mpeg with Media Player Classic instead and see if you get sound. It has its own mpeg decoder so it shouldn't be affected if there's a filter conflict causing the sound to not work in Windows Media Player.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
