Results 1 to 12 of 12
  1. I found a guide explaning how to convert SVCD to VCD:
    http://www.afterdawn.com/guides/archive/convert_svcd_to_vcd.cfm
    I did all the steps that were written there but after converting the AVSEQ01.MPG using VcdEasy from .dat to .mpg, The TMPGEnc did an error when i chosed the outpot file VCDEasy did:".... Can not open,ot unsupported.
    If some1 know what's the problem plz help,
    thx.
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Try installing the TMPGEnc MPEG-2 Plugin.
  3. Well i dled it , where do i put it and how do i install it? :/
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Put it in your TMPGEnc program folder.
  5. I extracted it into the TMPGEnc folder, ran the TMPGEnc and it still did the same error o0
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
  7. Sry for my ignorancy but this is my first time converting svcd to vcd.
    How do i use virtual dub in order to convert?
  8. Member teegee420's Avatar
    Dec 2003
    Southern California
    There's a link to a guide in my last post.
  9. i did what it said but when it start the frame server it just stay on 0 in all things and doenst do anything.
    I dunno what to do.
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    What you're supposed to do is open the .vdr file with TMPGEnc and start encoding. Frameserving means that you are serving frames to another program.
  11. Thx alot for ur help it worked.
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    You're welcome. Ain't digital video fun? :P
