    Nov 2002
    London, UK
    I have an AC3 and MPEG2 file and want to remux them under the merge and cut part of Tmpgenc, but it won't let me import the AC3 file.
    Under the other MPEG tools, like "multiplex" and "simple multiplex" it lets me import the AC3 file and will start to multiplex it, but not under the merge and cut tab. Does anyone else have this prob or know why it happens??
    I get the error message. "File VTS_01_1-audio is not an MPEG file" I hope I'm not answering my own question in thinking you have to multiplex then use the merge and cut?? That would be time wasting. Going through the process twice instead of once..
    Nov 2002
    London, UK
    I actually want to seperate into a number of MPEGs. I think the facility will do that in TMPgenc. I'll take a look at the AC3 link 8)
    Nov 2002
    London, UK
    Does anyone know why I'm getting no audio in my MPEG files using the merge and cut facility in TMPgenc??
    I demuxed froma DVD-R with Decrypter, remuxed with TMPGenc, but when I try and edit my MPEG with the "merge and cut" to make a shorter MPEG it comes out with a perfect video but no audio at all
    Nov 2002
    The merge and cut facility in TMPgenc can not cut mpeg file with ac3 audio.
    Mpeg-vcr can.
