I've got a few mpeg4 that I need to convert into something I can burn onto VCD or DVD. Toast doesn't seem to now what to do with them.![]()
Results 1 to 10 of 10
you need to export these as mpeg1 [vcd] or mpeg2 [SVCD/DVD]
once you get them in this format they should be good to go.
When you say tost wont handle them, are you in the VIDEO tab. I always assumed toast could take mp4 movie and convert it?!?! -
Yep in Video tab it comes up with an error saying it is in a format it doesn't understand. Plus Quicktime does open it but with the same error + no sound.
You need to obtain the proper A/V codecs for QuickTime Pro, try DivX Pro 5.07 or later.
Sounds like MS-MPEG4
Search Versiontracker for the codecs (v1 and v2)
Then use DivxDoctor 2 to get the audio to work. -
A new french application is out . This application could do that. It's name is "MovieGate".Originally Posted by kingarthur
It's in french language, but it's easy to understand how to use it.
You can download it there :
http://www.macetvideo.com/moviegate/moviegate.html
Before to run MovieGate, you neeed to install the same libraries than ffmpeg needs. (Just downlod and install the latest Ffmpeg to be sure to have the latest libraries installed on your computer).
Merci beaucoup! I will try it along with the other suggestions.Originally Posted by alkaline
I already have both of those codecs.Originally Posted by Thargok
Ummm hello its an MP4 NOT an AVI! DivxDoctor only does AVIs. :P
Converting .VOB files to MPEG4 with Streamclip and MPEG2 Playback Component
By MLK3329 in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 13:51 -
MPEG2 to MPEG4 conversion
By altavistasf in forum EditingReplies: 2Last Post: 11th Jun 2010, 23:35 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 06:44 -
Mpeg4 to make youtube video?
By chronic777 in forum Video Streaming DownloadingReplies: 8Last Post: 18th Jul 2008, 17:09 -
Converting extracted DVD files to MPEG4
By lglrgl in forum DVD RippingReplies: 1Last Post: 25th Dec 2007, 11:25
