Can anyone tell me what the main differences are between Premiere Pro 7,0 and Premiere Pro 1,5? or is it the same program?
Another question, what can you do in the Pro version that you cant do in 6,5?
Thx
Hakster
What would have been Premiere 7 was rebadged Premiere Pro. Premiere Pro 1.5 is the first major upgrade to Pro. You should check out Adobe's site for details as to what is new/better under Pro from previous versions. Lots of refinements, better audio mixing capabilities, probably a hundred and one little things.
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 17:21 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10
