The old HP finally bit the dust and I need a new printer desperately. My only requirements are these:
Must have refillable ink cartridges
Must print borderless
Must print high quality color photos from digital camera
I would really appreciate recommendations. Thank you kindly for your reply.
Thank You,
GolfNut -
I'm using a Epson photo 820 seems to fit your requirments. Not sure about the refilling, I was able to buy pre-packaged refilled cartridges so I guess it would be. The prints are great even at the regular setting, prints a full 8.5x11, does ocassionally have some faint lines at the beggining of the print when printing borderless. Inks cheap, about $22.00 per cartridge, Black and 5-colors . I had trouble with the inkjets getting clogged a lot but someone suggested I turn it off after use, hasn't been enough time to see if that works. It's pretty cheap too about $100 bucks or less the last I looked.
the coalman thank you for your reply and suggestion.
Thank You,
GolfNut -
How much do you want to spend up front and in supplies? Also how long do you want it to last?
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
New printer?
By bballnut in forum MediaReplies: 7Last Post: 4th Dec 2008, 13:04 -
Printer
By bryankendall in forum Newbie / General discussionsReplies: 5Last Post: 10th Nov 2008, 14:09 -
Printer Help....
By Jake802 in forum ComputerReplies: 5Last Post: 6th Jul 2008, 19:26 -
Printer Help
By zgrm100 in forum ComputerReplies: 3Last Post: 8th May 2008, 08:21
