I just captured video from my digital camcorder via firewire to my hard disk using VideoStudio 8. I want to use tmpegenc to encode the avi file to a vcd compatible mpeg. It gives me some error about not recognized avi file when I go to load avi file. How could I make it recognize the dv video avi file so I can continue? I've never had this problem before. Thanks.
Bytez
If you install the Panasonic DV Codec, you can use TMPGEnc to encode it.
Can be found in the tools section.
Chas -
One thing to add: some DV type I-II converter corrupt the sound (the canopus one usually has no sound after 4GB mark). So if you convert double-check the sound is correct for the entire file.
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 13:56 -
VFAPI aspect ratio change
By Weapon-X in forum EditingReplies: 1Last Post: 5th Mar 2008, 15:28 -
Is there VFAPI Alternative (For Windows Vista)?
By foochuck in forum DVD RippingReplies: 16Last Post: 4th Nov 2007, 19:02
