  1. *sigh*
    well...ive been using svcd2dvd for sometime now...and well....ive had enough with audio sync problems!
    lol
    time to shout out.
    every DVD that i make with the movies i download...has de-audio syncd....ive tried every setting ....
    the original files are never de-syncd...cause then the movies would be nuked(if you see where im coming from)....anyways
    please...ive had enough of seeing a persons mouth move...and 5 seconds later...the audio starts
    this doesnt happen at all times in the movie...but it happens around 5 times...and its really freeken annoying now.
    Anyone?! ...can anyone tell me what i need to do?
    btw, all the movies are in svcd format.
    Please help.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    https://www.videohelp.com/guides.php?link=518
    Also spilt up your content into different VTSs if they warrent it. i.e different sources/structures etc
  3. thanks boss.
    Ill try this method.
    Cheers
