Post your blank DVD Media Preference.
-Memorex DVD+R(Ricoh version)
*Haven't had any problems with them like some people have experienced.
Results 1 to 30 of 56
TY or Maxell for bulk, general backup (including data). Prodisc 4x printable for that "professional look". Prints all the way to the hub.
oh man i can see this starting a major war.
my fav. is CMC! esp memorex CMCs
pysch! :P
Naw, j/k, i like anything that is RICOHJPN as far as (+) goes, **** memorex tho, usually TDKs or Maxells.
(-) the MXLs i got from that office depot sale seem to work well, only burned about 3 so far.
i forgot, one thing i dont like about the maxells this that they have small amounts of fine strinngy dust-type particles on the write side, right out of the spindle!...i thought this was crappy, given their good rep. Maybe i just got an unlucky dusty batch
Yellow-Haired Warrior...Go -
I use 50 packs of Maxell printable shiny silver top DVD-Rs from Newegg- terrific media.
I Have an Optodisc 25 pack gold top 4x DVD-R spindle from Newegg but returned the rest cause they had problems (won't get into detail).
I Have made four perfect Memorex CMC DVD+R backups. :P Sold the rest cause wouldnt work in my laptop without bitsetting.
I use Ritek 2x DVD-RWs from allmediaoutlet. These are fine. -
Ritek Go4 Printable disks...
Pioneer A05
Think it would also help if folks put which burner they used as i looks like certain burners dont like certain media...Not bothered by small problems...
Spend a night alone with a mosquito -
Cursor 4x dvd-r (gsc 002).....cheap, very reliable, almost no coasters burnt with my nec 2500d
Taiyo Yuden 4x DVD-R
Maxell 4x DVD-R
Anything else is pretty much garbage!
I was really into using the TDK+R:RICOHJPN but I have found out about TDK using CMC, So I don't use them anymore, don't want to take the chance of getting CMC, Now it's Verbatim+R:MCC. I have a load of Maxell+R:RICOHJPN & a few Maxell-R:MXL just for the heck of it, so im very happy with that. I havnt had the pleasure of Taiyo Yuden yet.
So it goes like this
TDK+R 4X
Verbatim+R 4X & 8X
Maxell+R & -R 4X
Memorex+RW 4X
Plextor 708A & 712A
As you can see, I mainly use +R's all of my Standalone's love +R's even my Playstation 2 for Games and movies... -
I'd say DVD writer makes the difference.
I'm glad that I chose the Pioneer DVR-106 over the Nec1300 or other burners last year.
My friends always give me their blanks they can't write with their Nec1300 and LG4040.
To me it doesnt really matter whether its a MAXELL (TYG01) or just a RITEKG04.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I didn't know RICOH made DVD-R medias...Originally Posted by cmusngi29You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
www.nomorecoasters.com
I'm pissed off at TYG01 right now. My last 10 pack was mostly duds.
I had some TDK and MXLRG02 choke too.
I think it's time to clean the burner.Want my help? Ask here! (not via PM!)
no caosters ever so far on any of these media that i use, sony4x +r 4x+rw, comp usa 1x-r, teon 4x-r, memorex 4x+r, hp 4x+r, verbaitm 8x+r, imation 4x+r, phillips 4x+rw most of my 4x will burn in 10 mins so 8x speed, the verbatim 8x meida in 9 mins
here is what i currently have stock pilled
type,speed,format,how many i have right now
sony 4x+r's ( 8 )
sony 4x+rw's ( 5 )
teon 4x-r's ( 18 )
verbatim 8x+r's ( 2 )
imation 4x+r's ( 20 )
phillips 4x+rw's ( 4 )
compusa 1x-r's ( 22 )
never made a coaster yet and have burned over 200 dvd's
oh yea...how do you go about doing this? personally i use canned air (make sure to hold it upright :P )Originally Posted by lordsmurfYellow-Haired Warrior...Go
Maxell 4x DVD-R White Printable
Taiyo Yuden 4x/8x NON Printable.
I pulled out my A03 the other day just to have a look see at the insides. Keep in mind, this drive was made in June 2001. It was spotless. Not one bit of dust, or anything.
To clean the drive, take it apart and use a high quality cotton swap (Q-TIP brand works well), with a 50-50 mixture of rubbing alcohol and water. Make sure the Q-TIP isn't dripping wet, and gently swab the laser. Allow time to dry, and reasemble.
This should only be done in extreme cases. Like if you live on a dirt road in Arizona/Texas, or blow smoke inside the drive constantly with the tray open. You should really never have to clean the drive, unless you let dirt/dust get inside it.
Shooting compressed air inside you drive can be bad. The force of air could knock the laser out of alignment, or if there is dust inside the drive, it could scratch/cover the laser. -
Compressed air cans often have warnings "not to be used on camera lenses". A DVD burner is not a camera but I would not want to risk using something possibly abrasive on the laser.
Maxell 1X DVD-RW (Made by JVC)
Maxell 2X DVD-R
Maxell 4X DVD-R
Maxell 4X DVD+RW (RICOHJPNW11)
Maxell 4X DVD+R
Memorex 4x DVD+RW (RICOHJPNW11)Sam Ontario -
Ricoh Japan Revision 1 DVD+R (4x)
(Branded as Fuji, Maxell, Memorex, Sony, TDK & Ritek)
Ritek Silver Top DVD+R
Zero defective discs encountered amongst these.If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Whats CMC ?[/quote]don't want to get a chance of getting CMC
With my burners:
Plextor 708a loves Memorex 4x (any Ricohjpn01) and burns them at 8x.
Pioneer A05 likes almost any decent -R media. Burns almost anything that has a -R attached to it. But mine defnitely dont like Princo's and Optodics 1-2x. Best speed is 4x on all -R. My most dependable -R burner with decent media like G04.
NEC 2500a likes Ritek G04 and Prodisc S03. Using Herrie's latest FW (HP/2510 DL) can burn these 4x at 8x. Now if I can only get my hands on some DL DVD for testing. I previuosly use this burner for experimenting and to test FW patches since most FW hax's hasnt been really realiable on my NEC. But with the newest FW from Herrie, I am now using the NEC to burn -R more then the A05, good quality but mainly for its speed.
Only use Ricohjpnw11 in the +RW since they are 4x. Dont use -RW (2 slow) except occasionally the Pioneer one that came with the A05 just to test -RW compatibility of a burner.
If I had to burn a 100% dependable DVD, then definitely the Ricohjpn01. They are perfect with the the Plex and works well with my NEC also. -
After using ProDiscS03 for a short period I think this is my new favorite not only becuz they are cheap (price-wise that is [$44 for 100 DVD-R]), but they burn faster (less than 15 mins) than any other 4x media (+ and -) I have used (MCC, Ricoh, Maxell, CMC), tests show no read errors, and they play back flawlessly on PC and settop. Now if they only last for a while I'll be sitting pretty
Memorex 4x DVD-R (Prodisc S03 flavor)
FUJI 2x DVD-R (Ritek G03 flavor) Will burn at 4x on TDK with 1.02 firmware -
Optodisc gold DVD-R for the Panny E50 and Maxell branded DVD-R for the PC burner.
Wow, capmaster, we use the same two kinds of DVD-Rs, Optodisc and Maxell (I use non-branded). Personally,after initial good experiences, I have found the Optodisc gold tops to be mostly shit, even at 2x! The Maxells on the other hand are another sign of glorious Japanese quality and are the cadillacs of DVD-Rs.
Maxell 4x DVD-R's & 4x DVD+R's all the way had problem with about 6 other brands now I stick to these they are almost always on sale at Future Shop.
1.Verbatim DVD+R 2.4x Inkjet Printable (MCC Singapore) Not one coaster in 4 spindles. Hard to find in stores.
2.Maxell DVD+R 4x (Japan made 10 packs) One coaster in 40 used. Fairly easy to find.
3.TDK 4x (non-CMC) No coasters. Easy to find. *Haven't tried the CMC version TDK, may be ok if TDK has any type of control over the manufacture.If it works, don't fix it.
Price of blank DVD media - Why gone up in the economy?
By contract73 in forum MediaReplies: 21Last Post: 9th Sep 2012, 12:58 -
AccountKiller
By rcvalle in forum MediaReplies: 6Last Post: 15th Dec 2010, 14:27 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
What's you choice when it come's DVD-R blank media?
By mrjust in forum Off topicReplies: 4Last Post: 24th Mar 2010, 21:24 -
Blank DVD Media
By jason in forum Newbie / General discussionsReplies: 21Last Post: 2nd Dec 2008, 12:40
