Are their any tools out there that check for errors such as pixelation, skipping and freezing of frames on the DVD? Presently, I watch the whole movie to see if there are any problems. I use the verification process in Nero after burning. Does Nero check the DVD to see if there is no pixelation problems and so forth?
Thank you
nero cannot check for "pixelation problems and so forth."
i have never heard of a program can check for visual problems w/ the disc.
try nero CD/DVD speed or DVDinfo pro and do a surface test and transfer rate/quality test. These test by seeing how fast the drive can read the disc. Faster read (less/no spikes) = less errors.Yellow-Haired Warrior...Go -
Well there are several things you could try. As mentioned above, use DVDinfopro, of if you have a liteon burner k-probe. There is also Nero cd-dvd speed that some people use. Another thing to use is PowerDVD, just FF at top speed like 32x or 64x, I forget which, the DVD will usually lock up or pause at points that have playback, and other problems. You could also FF in you DVD player too, as PC DVD drives tend to be more forgiving. For me my DVD player scans at like 64x, so it doesn't take too much time to go through discs, and it pauses/freezes at read errors.
Oh yeah, none of these methods check for video problems per se, but instead check for read errors, which are commonly associated with pixelation and such.Blah, blah, blah -
i anaylze the dvd with dvdshrink...sasarchiver
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 16:25 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Burned DVD ISO playback errors
By Silver_Ice in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 13:24 -
DVD-R playback errors
By blas in forum MediaReplies: 5Last Post: 6th Dec 2007, 13:58 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
