  1. Hello,
    when i make a new menu with the integrated menu maker, there is a button to draw buttons or delete buttons.
    I cannot click it, both greyed out.
    Thx for your help
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    That is because the buttons on the menu are governed by the VTS structure within SVCD2DVD. If, for example, you have 3 VTSs you get three buttons. (see Walkthrough document)
    The toolbar buttins are still there but greyed out as you can start DVD MenuMaker on its own & thus create your buttons from scratch. The resultant menu can be used by SVCD2DVD at a later time.
