I have been using the VCD Easy's for putting "chapter" marks on the movie. With that said, you know how you play the movie it plays starting with chapter 1 and then it moves to chapter 2, and all is well. However, if you press "Next", it goes back to beginning of chapter 2 instead of chapter 3. I've tried splitting the movie into different files, but all that accomplishes is having a brief pause inbetween each chapter, and I don't like that. The entrypoint limitation is not a big problem for me, but if there is an uncomplicated way to get around it, I might want to try it.
Nope, there is no way around it. The only other method is the one you tried with using separate tracks, but the pause you get is far more annoying then the illogical navigation you get with entrypoints. Its just something you have to live with.
? about scan limitations for AV programs
By Seeker47 in forum ComputerReplies: 1Last Post: 10th Feb 2011, 14:15 -
MPEG-limitations in AVIdemux?
By Gew in forum EditingReplies: 9Last Post: 9th Apr 2009, 08:55 -
Limitations of Ulead DVD Workshop2
By raouliii in forum Authoring (DVD)Replies: 10Last Post: 20th Oct 2007, 01:42 -
Area Limitations
By jmsrickland in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2007, 21:10 -
Playback prohibited by area limitations >8(
By Flare in forum MacReplies: 3Last Post: 17th Jul 2007, 17:38
