i'm using virtualdub and the latest adobe premiere.
I've captured a few small 1 minute avis from my camcorder and have imported them into premire (to a default 720x480 sequence). i was succesfull in exporting the smaller 320x240 avis to dvd. both of them coming out as 720x480 resolution on the dvd. the trial runs turned out great, so i proceeded to the actual project. . .
but when i tried to do the same for the actual full lenth (1 hour) project the video exported to the dvd as a smaller box inside a larger black box.
is there something i'm missing?
i've fooled around with it for about a week, and i can't reproduce what i did the first 2 times.
after fixing countless driver and hardware problems, i'm so close to being able to do this. just this one last hurdle.
i'll have internet access at home soon, so i will post screenshots if i have to. any help would be appreciated.
thanks.
sounds like your image is staying 320x240 inside a 720x480 frame. check exactly what filters and settings you're using in Vdub.
yes, thats exactly whats happening.Originally Posted by flaninacupboard
so you think it could be virtualdub. . . i kept thinking it was the settings in premiere.
thanx, i'll mess around with it tonight and see if i can fix it. -
320*240 is not a valid DVD format. It needs to be resized. 352*240 would probably work without borders.
Google is your Friend -
352x240 is also the closest DVD resolution to your source so that's the best one to pick. Upsizing too much will cause blockiness and artifacts, it's best avoided.Originally Posted by Krispy Kritter"Art is making something out of nothing and selling it." - Frank Zappa
standard 720x480 DVD to Avi 720P with free converter?
By MilesAhead in forum Video ConversionReplies: 26Last Post: 26th Apr 2010, 18:44 -
How to Crop a 720x480 video to make it 320x240?
By alc112 in forum EditingReplies: 3Last Post: 11th Jan 2009, 00:42 -
Issues converting to 320x240 AVI
By 009 in forum Video ConversionReplies: 5Last Post: 14th Jul 2008, 03:23 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
Ripping DVD to avi 720x480 using FairUse2?
By suneo in forum Video ConversionReplies: 11Last Post: 28th Oct 2007, 08:11
