In my job, we capture a lot of short DV uncompressed AVI's and I am trying to figure out the best way to convert them all everyday. In a given day we end up with upwards of a couple hundred short videos (10 seconds is average length). So I am looking for a good command-line based video encoder so I can do a bunch of batch encoding. I'd like to be able to encode in something like DivX or maybe just use an Indeo encoder. In any case, I need a command-line based program where I can control the bitrate and be able to specify the video to set a keyframe on every single frame of video (so I can easily scrub the video anywhere).
I have been looking at ffmpeg. Seems quite powerful, except I am confused on how to tell it exactly what format to encode in. I'm not sure what is best. And I can't figure out how to make it keyframe every 1 frame of video. Does ffmpeg use any codec? Or just it's own codecs? Can I encode DivX with ffmpeg? Can anyone help me?
Jakobud
keyframing EVERY frame in Divx is enirely pointless. the size/quality it achieves is because it has maybe one keyframe to 200-300 delta frames. kill those delta frames and your video is hosed.
Try MJPEG.
don't know a command line editor, but TMPGenc is a powerful bit of kit that you can create a template for and encode with the same settings every time.
Anyone Can Help to Convert This Preset to FFmpeg Command Line?
By raymng in forum Video ConversionReplies: 2Last Post: 26th Feb 2012, 12:11 -
ffmpeg / H264 (need help to build an optimized command line)
By iwiiiiiiiiii in forum Video ConversionReplies: 13Last Post: 22nd Oct 2011, 10:41 -
ffmpeg generate audio/add to video help please, command line
By surfmonkee in forum LinuxReplies: 3Last Post: 11th Sep 2011, 16:17 -
ffmpeg tga to x264 command line ?
By krohm in forum Video ConversionReplies: 71Last Post: 6th Jul 2010, 02:01 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29
