I have a Sony subwoofer that has a light which turns green when it is detecting a signal and turns red when no signal is being detected. The light is almost always green when I watch TV & play CDs, but it is almost always red when I play DVDs. It will turn green when there is a big explosion or something like that (and it will send out a killer sound), but the subwoofer remains red for about 90-95% of the time when I watch a DVD. I have all the settings at the recommended levels, but I am using the standard cable that the subwoofer came with. Would a better cable allow my subwoofer to detect signals better from DVDs? Any recommendations? Thank You!
it's probably behaving correctly, dependant on your amp settings it may only be very low frequency signals that are sent to the sub. for instance, if your surround speakers are set to "medium" or "large" there's not as much bass redirection as when they're on "small"
Sound only coming from subwoofer
By jeanpave in forum AudioReplies: 11Last Post: 5th Oct 2010, 00:24 -
Subwoofer and speaker problems
By HartsVideo in forum AudioReplies: 10Last Post: 20th Sep 2008, 12:18 -
Subwoofer Help
By levon in forum AudioReplies: 9Last Post: 3rd Sep 2008, 13:41 -
Connecting subwoofer to amp - quick cable question
By heyjjjaded in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 14:04 -
Seting up a subwoofer: what is a corssover? Energy S8.2
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2007, 00:44
