Well forgive me if the anwser is somewhere else.![]()
I'm new at burning dvd's & need a little (BIG) time help.
Can you or can you not make a working DVD that will play in most home players using Nero 6?
If so what have I been doing wrong, I have three MPEG-2 & one AVI movie just waiting to burn, thanks!
I've been going svcd on cdrom's before I got my DVD/RW & now want my new one's on DVD.
I have TMPGEnc but not installed yet and wonding do I have to make dvd's?![]()
Results 1 to 17 of 17
Well I found something that I'm no good at.
Nero 6-Use the DVD VIDEO template. Click the ISO tab,file name=ISO level 1,character set=ISO 9660,un-check Joliet,uncheck relax ISO restrictions.
Works for me on all DVD players including "ancient" Toshiba from 1999. -
Forget those settings, Nero Express, DVD-Video, put all your VOBs, BUPs, IFOs into the VIDEO_TS folder (automatically generated by Nero) and youre all set
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
But first you need to convert those mpegs to DVDOriginally Posted by packman63
Use TMPGEnc DVD Author
If those mpgs are not DVD compliant see next conversion guide
For the avi to DVD conversion you can use DVD2SVCD
https://www.videohelp.com/forum/userguides/111846.phpYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
So as to avoid confusion, do NOT use Nerovision Express to encode your files. Install TMPGEnc and encode using the wizard.
Take resulting mpeg, and import into TMPGEnc DVD Author or DVDLab.
Add chapters and menus as you like.
Burn in Nero Burning Rom, or use the built in burning software within the authoring app. Both TMPGEnc DVD Author and DVDLab have basic, yet functional burners built in.Cheers, Jim
My DVDLab Guides -
#1 Nero rookie mistake: The contents of the Video_TS folder has to go into the nero Video_TS folder. It's backwards from VCD/SVCD, where you drop the MPEG into the 'work' area, not the file structure above it. Don't put a video_TS folder into another one. That's for "Authored" files (VOB's/BUPs/IFOs).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks tompika,reboot & allOriginally Posted by reboot
Well I've added TMPGEnc DVD Author, but am getting this.
ERROR This is an illegal video file.
For DVD-Video you can only use the following video formats:
MPEG-1 Video, MPEG-2 Video
TMPGEnc DVD Author does NOT have MPEG encoding abilities.
I would like to get this file in,MPEG Layer-3 any thoughts or help again?
Thanks a bunch
Well I found something that I'm no good at. -
TMPGEnc and TMPGEnc DVD Author are two completely different programs.
Encode in TMPGEnc. Author in TMPGEnc DVD Author.
Burn in Nero.
Although they are good basic programs, they both have limitations/faults.
I much prefer to use Mainconcept Mpeg Encoder or Canopus Procoder to encode, and DVDLab to author.
Just click on the names
Cheers, Jim
My DVDLab Guides -
You can try the trial version on TMPGEnc XPress 3.0.
Very easy to useYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Once again guys thanks a bunch for the added info!
Going to give them all a chance & see what happens.
I'll be back if I need more help, thanks again.
I Am Canadian beers on me
Man I need a good tutorial.
Even got DVD_lab cant get it working.
Ahhhhhhhhhh..
Don't forget your choice of media can also affect the cross platform compatibility - some DVD players in particular are very unforgiving beasts and have a preference over media manufacturer and book type.
Thanks I figured that,all I know is that if I can make a normal svcd on rom that works on mine.
But cant figure out why I cant get this dvd thing, I know its not my player, tried the two on three players.
I have to find a software called DVDit, so my bud tells me!
btw, tx garry for your info & time to post.
No, please, don't use dvdit. Like Playskool toys, not for big boys.
Look in the guides. Find one you can use for TMPGEnc.
Then use this one for dvdlab: https://www.videohelp.com/guides?link=602
Once it's finished, burn in Nero, or use DVDLab's built in burning engine.Cheers, Jim
My DVDLab Guides -
Thanx reboot.
I'll try it "again" as you say tit for tat using the linK.
I could have done something wrong the first time, but thats how I did it..???
You'll get it. It's a series of important steps, that must be done to get a finished DVD.
1.) Encode to mpeg2, dvd format in TMPGEnc.
2.) Author it in DVDLab as per my nifty tute
3.) Burn it in Nero Burning Rom.
If you have any specific questions about using any of those 3 programs, please ask. Don't make coasters, if in doubt at all, use a DVDRW first!Cheers, Jim
My DVDLab Guides
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 06:17 -
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 11:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning Videos to DVD with Nero 9
By GeneYuss in forum Authoring (DVD)Replies: 6Last Post: 22nd Dec 2008, 08:11 -
Nero dvd burning, disabled?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 14:55
