    Jan 2004
    Canada
    as the subject says how would i put 2 mpg files into one .mpg?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    You can join them with TMPGEnc. Go to File>MPEG Tools>Merge and Cut.
  3. Member DVO's Avatar
    Apr 2002
    You can use the MPEG Tools in TMPGEnc (free for mpeg-1). File > Mpeg Tools > Merge & Cut. Load the two mpg-files in right order and select output file name. Run..
    The files need to have same bitrate, framerate etc. Or you have to reencode them.
    I personally don't recomend merging mpg-files if they store audio, I always get it out of sync, especially mpeg-2 files. I keep it as two files instead, I prefere a small glitch on a VCD for 1 sec rather then out of sync sound the whole movie
    (Edit, Oops too late, hahaha)
