Page 2 of 2
FirstFirst 1 2
Results 31 to 41 of 41
  1. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    But this forum is based on opinion (almost) as much as it is based on fact and technical knowledge.
  2. Originally Posted by Supreme2k
    That's true, but I think most of the time, opinion can be clearly delineated from the facts, unless the person doesn't know what he/she is talking about.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    It may be too late, but I've started a new thread in order to curtail the threadjacking.
    I think that the original question was answeed and/or solved several times.
    Jul 2003
    Minnesota, USA
    I'm not posting on the other stuff I decided this is a help site so I'll post my findings in the hope of helping others.
    The DVD in question seemed to have a problem with ATI DVD player software. All the computers we tried playing it in, had ati software. I found after the attempt it wouldn't play other dvd's either. Including ones it would previously play. Fixes ranged from repair installs of the software to setting dvd region to uninstall/reinstall of the software in question.
    The DVD that caused this problem was a video of a live music concert by mercury records. Maybe a new copy protection?
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Doubtful. Did you try removing ATI DVD Player? All you have to do is run the uninstaller from control panel and choose "modify". Uncheck "DVD plaer" and away it goes. I got rid of it a long time ago. Power DVD is a much better player anyway.
    Jul 2003
    Minnesota, USA
    For one of them we did remove ati dvd player and put powerdvd on for him. But now that seems to be having trouble with some things as well. Won't get all the way through other dvd's. I should get a look at that computer later after he picks this one up.
  7. Member teegee420's Avatar
    Dec 2003
    Southern California
    If it were me, I would download all the latest ATI drivers and MMC(including the handy little uninstall utility) and remove all ATI products, then re-install everything. You might even want to consider re-installing XP over the present installation as a last resort.
    Jul 2003
    Minnesota, USA
    thanks I will probably try that. The computer with xp is working fine though the last problem system is running win 98se so..... I'll try uninstalling and reinstalling and updating... I'll try to get back to you as soon as possible.
    Jul 2003
    Minnesota, USA
    one question about going to powerdvd over the ati... His ati card has hardware decoding as opposed to software.... will powerdvd use the hardware decoding?
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    Yes it will. To be more exact, it uses hardware acceleration. You may have to enable it in the options menu. I don't remember if it is set as default.
    Jul 2003
    Minnesota, USA
    thanks Teegee! I don't have a DVD in my computer at home and with me, if I haven't HAD to do something for some reason I don't go out of my way to find out everything there is to know.... I love computers but I get fed up, when I'm home I don't ususally want to mess with stuff...
