I recently set up a home network with a dlink 604. Since I've done this I can no longer use the voice conversations in windows messenger. I've searched a lot for a fix or settings change but I can't find anything that helps.
So far I've made sure the router was set to enable uPNP. I've also made sure that the ssmp and upnp services, i think thats what they are known as, were enabled and running on windows xp. The odd thing is that when I enable dmz on the firewall it still won't work. I was under the impression that that opens up your computer so that no firewall is present.
Voice converstions worked fine before i installed this router so I'm thinking its something with that. I read that messenger uses dynamic port allocation for video and voice so that that stuff will work when there are other programs running that could use similar ports. So I openned up that port range that microsoft provided and I also openned up port 6901 which is suppose to accept the incoming voice info. None of that has worked. If anyone can provide info to what could be causing this problem I would really appreciate it. Thanks in advance.
One answer made fresh to order....
http://support.dlink.com/faq/view.asp?prod_id=1170&question=DI-604%20/%20DI-614+%20/%2...4%20/%20DI-764
Hope that helps."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Thanks for that link but I have those ports forwarded already on the firewall. Those entries were automatically configured when I installed the router. I wish it was that simple. If anyone has encountered this same kind of situation any advice would be helpful cause this is really bothering me.
Is your Messenger using the same ports that MS specified?
I had the same problem with my DI-614+ DMZ not working... now I have an SMC router, and am much happier with it.
Windows Messenger
By Jomapil in forum ComputerReplies: 16Last Post: 11th Feb 2010, 10:06 -
Samsung Tocco Lite On O2 Windows Live Messenger?
By Nitro89 in forum Off topicReplies: 0Last Post: 18th Jul 2009, 17:07 -
Possible router problems.....
By SE14man in forum Newbie / General discussionsReplies: 21Last Post: 25th May 2009, 23:05 -
Windows Live Messenger Problem
By Anakin in forum ComputerReplies: 0Last Post: 27th Feb 2009, 13:55 -
How to KILL Windows Media Player, Messenger & Outlook Express?
By fLYtRap in forum ComputerReplies: 36Last Post: 2nd Aug 2007, 01:18
