  1. Is it possible in XP Pro to turn off hyper threading by application?
    I would like to leave it on globally on my PC but selectively turn it off for one or more applications installed on my PC. Is this possible?
    There is a reason why God gave us one mouth and two ears!!!
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    if the application has support for the control, yes, otherwise i don't think so. it may be possible with a registry hack - google is your friend
  3. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    thought i'd add this in, browsing toms i found this article.
    http://www.tomshardware.com/cpu/20040528/task-assignment-01.html
    if you assign a task to CPU 0 only then that task isn't using HT anymore.
  4. flaninacupboard,
    thanks! Just what I was looking for!
