Well i have dled a certain movie and got 2 files a bin file and a cue file.
I used Daemon tools to play the bin on my computer using powerDVD, but i also want to play the movie on my DVD.
I wasted like 7 discs trying to burn this movie but none worked:
Tryed extracting the bin and burning the files there on a disc but that didnt worked.
Tryed Converting the bin to iso and burn with nero , didnt work also.
So i ask how can i burn the movie so it will work on my DVD?
btw,
when i extracted the bin i got this files:
EXT, SVCD and MPEG2
Thx in advanced,
DesperaDo
Try looking up your DVD player in the DVD Players Section to find out if it can play SVCD's. If you still have the cue file, just select that in Nero when you go to File>Burn Image.
If your player supports VCD, then there's a simple trick to getting the video to play. Hunt around for the "VCD Header Trick", somewhere in the guides
Cheers, Jim
My DVDLab Guides
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 15:28 -
Magix Movie edit Pro 15 Burning problem
By wolfspirit1964 in forum Newbie / General discussionsReplies: 1Last Post: 24th Feb 2010, 03:56 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Problem to play my convert movie in Mediaportal
By Cazz in forum Video ConversionReplies: 4Last Post: 4th Oct 2008, 08:36 -
magix movie edit pro 12 burning speed problem!
By SKATEBOARDEDITOR in forum Newbie / General discussionsReplies: 6Last Post: 14th Dec 2007, 04:47
