  1. Hi all... i have a Avi file but the audio is really low is there any way if increasing it so i don`t have to turn the tv volume up as far as it goes , mind you even then it`s not that great.
    My prefered proggs are Virtualdub/virtualdubmod and Tmpgenc
    Thanks ...Simmmy
  2. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    Depends on the audio format used
    If mp2 or wav then Tmpgenc can do it (never used myself)
    settings->audio - use audio edit - settings - change volume.
    Or use any waveditor Goldwave (free) / Soundforge
  3. Many thanks...i`ll change the audio to wav and see what happens from there...
    Simmmy
  4. Just for the record Tmpgenc worked a treat ...again thanks Roderz.
    Simmmy
