I have a panasonic EX3EN digital camcorder and want to use toast 6 plug n burn to convert my dv tapes to DVD,(I am not worried about editing) I have converted some tapes no probs but any dv tapes that are over an hour puts toast 6 into a coma after it has finished importing? (the color wheel spins for hours and wont respond, I have to eventually force quit) if I select the length to 30 mins no problems, but if I try to do the second half the same way it goes into the coma again, I have overcome this by importing the second half to imovie and then back to the camera and then back to toast 6, this is crazy and defeats the purpose of toast 6 plug n burn. there must be a better way. can anybody help, please???
In this case the updates fixed a lot of problems that were in the original Toast 6. You don't have to delete the original one to do the update. The Toast update is simply a new version of the application and does not modify the original version so you can keep the original until you are ready to delete it.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 15:55 -
Cant burn Video TS in Toast
By 3lutz3toe in forum MacReplies: 21Last Post: 11th Sep 2009, 17:31 -
How to burn toast file in windows XP?
By yunakokimama in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2007, 18:01
