Is there a simple way to tell ffmpegX and all encoding/decoding tools to create their temporary files in a certain directory? It seems that these files are always created in the user's home directory (some file named stream.yuv etc)? My home directory is located on a volume mounted over the network, this makes things quite slow...
-aehrisch
Location of codecs
By pooksahib in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2011, 15:29 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
why canīt find FLVs downloaded by means YOUTUBE on IE7 temp files folder ?
By RonWolpa in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2007, 07:16 -
Video and audio files are split in temp. file
By SSH1968 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2007, 17:50
