i cant strip this audio from a avi with vdub
0x0055(MP3) ID'd as MPEG-1 Layer 1
gspot says i have 4 codecs available,,,but vdub says dont have the compressor for it
Are you trying to strip the mp3 or do you want to decompress it to wav? If it's the latter, use Goldwave instead. I had the same problem as you a while back and for the life of me I can't remember how I managed to fix it. All you can do is work around it for now.
i'll give goldwave a shot,,when i send the file with the above listed audio tmpge or msp dont show it having audio,,vdub wouldnt yank it and msp put it to wave but when i played sound file back alone there was no sound,,which i dont get if it plays with sound in media players i should have the codec for it
I suspect the problem lies somewhere in the registry. Now that I think about it, I'm pretty sure it was Norton Windoctor that fixed the problem for me.
i have the codec already,,i guess alot of avi/xvids just have corrupt audios or something,,thing is i can re-encode with dr divx with no problem,,so if that picks up the audio then the other progs should to i would think
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
Can't decompress Ripbot264
By ranchhand in forum DVD RippingReplies: 3Last Post: 10th Apr 2011, 23:02 -
Better to Decompress First?
By FrozenInferno in forum EditingReplies: 20Last Post: 25th Feb 2011, 01:48 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 01:59 -
Decompress AVI
By anirban in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2008, 20:25
