i resently obtained a .bin and .cue file for a movie and would like to compress it into divx or preferably mpeg2 and im running MacOSX, can NE1 help??
Cue file: cuesheet files
Bin file: image files
You can burn those files into CD or DVD with Nero Buring ROM
You can open them with IsoBuster: http://www.smart-projects.net/isobuster/
as for macintosh conversion of .bin/.cue to DIVX you should visit my website.
there are a host of ways to go about this, one of the easiest is to extract the mpeg files using VCDTOOLSX and then begin the conversion of mpeg to divx.
i do it by first creating a VIDEO_TS folder with Sizzle. This makes the files dvd compliant [when/if you ever want to burn it over to dvd] and then makes them acceptable by the great and glorious Handbrake which will do dvd [video_ts] to divx with one simple click
its a round about way, but its by far the easiest for "newbies" and those who are not familair with the ffmepg types of conversions.
hope this helps -
Since you have disc image (bin/cue) i would just burn it as is. Most likely it is a VCD or SVCD version of a movie, which you can play on standalone dvd player (and on your computer as well).
Converting VCD/SVCD to divx its kinda pointless, you won't get better quality out of it - you can preserve existing quality at best; but you won't be able to play it on a standalone dvd player; the only advantage is that you may save some space on hard drive if you encode VCD/SVCD to divx. -
agreed... this woudl be the easiest
but if they are wanting to reduce it to a 700 meg divx which will fit onto one cdr it is possible, but yes drastic reduce in quality compared to what they have as .bin/.cue
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
