Hello
Would someone be able to give me some advice re codec compression and my AlchemyDVR card on my Mac?
Ive had the card for several months and think it is a very fine product. My computer is a G4 dual 1 GHZ with 780 RAM. 4 X 250GB HD’s
Using a cable TV connection I find that I get :
MPEG4 1:2 340 x 240 at codecs quality 75% = 2 gb /30 min with good Audio/Video synch.
Sorensen3 1:2 340 x 240 at codec quality 75% = 1.7 GB/30 min good enough A/V synch.
I open this QT file in QT pro and do a little editing, and export it as a QT MPEG4 same 340 x 240 30f/sec with video at 1040 kbits/sec and this file is about 250 MB and good enough for my purposes. This file type for now is my final goal.
Is there a way to get this same final file from the AlchemyDVR? It takes my computer about 15 to 20 min to do this final export and Id like to avoid it if possible.
I also do not understand why files MPEG4 from the Alchemy are so much larger than the ones exported a second time as describ3ed above.
Im using the version 1.0.10 of Alchemy DVR as I have downloaded the 1.2 but was told in a previous email that I could not just reinsert the current pref files back into the new version and wish to avoid reentering all my TV shows again in v 1.2
Thanks very much for any help.
rotut
Are you sure your DVR is outputting mpeg4? Not mpeg2?
He is correct; the Alchemy card does not output to MPEG-2. Otherwise, things would be easy!
I don't have this card, but have you been to these pages? Maybe your answer is there.
http://www.xlr8yourmac.com/G5/AlchemyTV_card_reports.html
http://www.miglia.com/Support/alchemytvdvr.html -
My mistake I guessOriginally Posted by harvid
It was just that 2 gig seems incredibly large for a 320x240 mp4.
MPEG4 video player (and codec?) for Windows ME
By JamesC2000 in forum Software PlayingReplies: 1Last Post: 12th Jan 2012, 08:07 -
FFMpeg: YUV422 and MPEG4 Video Codec
By HypnoBeard in forum LinuxReplies: 6Last Post: 27th Sep 2011, 00:10 -
Xvid mpeg4 codec ?
By 3thman in forum Video ConversionReplies: 0Last Post: 15th Sep 2009, 01:31 -
Best MPEG4 compression codec?
By W_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jan 2008, 07:12 -
MPEG4 codec problem
By kris3 in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2007, 02:57
