  1. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    You can also join our chat using IRC, use for example mIRC and join the channel #videohelp under the IRC Network Dalnet (both the webchat and the IRC chat are the same chat).
    IRC Network Dalnet? could somebody tell me the exact server which i will type in the server textbox in my MIRC...im a newbie in MIRC.
    hacking the Net using typewriter :D
  2. Member adam's Avatar
    Sep 2000
    Mirc has a list of default servers you can join. Just pick any Dalnet one you want, preferably one closest to your region. Just read the Mirc help file to find where to pick your server. You shouldn't have to type anything.
  3. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    thanks adam...so i will use the random server of dalnet and just join #videohelp...
    another question please...is the java chat applet of this site still working, coz i click "Click here to start our Java Webchat" but
    NO security popup window appeared that says
    Do you want to install and run "jIRC applet..."
  4. Member adam's Avatar
    Sep 2000
    The Java chat works fine for me.
