Hi!
I dowload from the web a PAL mpg file.
When I try to burn it using VCDEASY the program says that I have only one entry for chapters.
Is this related to PAL format?
Because I usually convert to NTSC.
Or is because the file is 756MB and I am burn it in a 850MB CD-R?
Thanks.
PAL is innocent, you would have about the same number of entry points as in NTSC. Its a big chance your mpeg file is screwed, its not properly encoded. It should work ok anyway, so you could try to "relax APS constraints" in VCDEasy to se if that will give you more entry points.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
converting PAL DVD to NTSC while preserving chapters
By andreyvul in forum LinuxReplies: 10Last Post: 2nd Sep 2009, 04:04 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
PAL to NTSC, Menu, Chapters
By heretic754 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2007, 14:46
