When creating new DVD encoded with TMPGEnc, from AVI files, and authored with any kind of DVD Author program (TMPG; Ifo Edit;...), I usually find a strange thing in the quality of the resulting film image. It seems that the frames repeat themselves (two by two, or three by three), and what should be a soft transition looks like a step by step film. The encoding template has everithing OK (25fps, PAL, CBR...)
The original, previewed with WMP seems perfect, so I think it must be an author/encoding problem.
Any suggestion?
Authoring and encoding are of course 2 completely seperate steps.
If your original AVI was ok and the encoded Mpeg was jerky , I would suggest that you are trying to convert a NTSC file to PAL. That will result in jerky playback.
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 18:28 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 07:23 -
Problem with DVD Author
By JCWBobC in forum Authoring (DVD)Replies: 1Last Post: 12th Jul 2009, 02:55 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
WMV. Problem to author a dvd....
By mngwdw in forum Video ConversionReplies: 2Last Post: 27th Jun 2007, 16:00
