Hello again,
I know similar questions have been asked before about this sort of thing, but I don't think any really pertain to this topic. I am the owner of the Canopus ADVC-100 and Adobe Premiere. When I import video from my analog VCR or camcorder, I notice noise at the bottom of the video. I know there are ways to remove this after the capture but I would kinda like the process to be simpler. I was wondering if there were settings in Premiere or another program, to cut out those lines WHILE doing the capture. That way, I could skip the step of cutting out the noise. Any help would be greatly appreciated.
Thanks!
Short answer ... NO
The Canopus ADVC-100 simply converts analog video to DV video. You should be then capturing or rather transfering that digital data being sent to the computer from the Canopus ADVC-100
You can't "alter" it as you capture to DV AVI
So you must crop and fill after the fact which is very easy to do and doesn't really take up much processing time anyways so it's not a big deal as I see it.
Thank you, I guess I'll just have to remove the noise after the capture.
please list the virtualdub filters to remove vhs tape video noise
By perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 13:45 -
How to remove noise from my HD video
By ITW in forum RestorationReplies: 18Last Post: 26th Jan 2011, 13:24 -
Cleaning Up/Remove video noise
By Soixante in forum Video ConversionReplies: 5Last Post: 5th Apr 2010, 19:34 -
how to remove heavy noise in video?
By Driftking978 in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2008, 05:24 -
Remove noise garbage from bottom of video.
By mlong30 in forum EditingReplies: 24Last Post: 10th May 2007, 22:41
