I'm using nero to burn some files into a dvd, and when it reach half way through. the whole system would freeze up. Of course it's another dvd+r wasted. I'm using TDK dvd+r. any idea what is going on?
You more then likely have a thermal problem.
But, you failed to provide any information in your profile so its a little difficult to help you.
What computer?
Operating system?
Processor?
Why not use DVD+RWs and save the media. -
winxp
athlon xp 2800+
512mb ram
latest nero
I just got it flashed to 1.12 w/ pioneer official firmware. going to try to burn again w/ dvd-rw -
great, froze again. cpu temp was at 50c, mb temp was at 36c
should I flash mine with http://www.pioneeraus.com.au/computer/firmware.html 1.15?
also I burned a cd-r ealier and it works perfectly fine...
just flashed to 1.15.. same thing.... this is getting to be very disapointing *sigh...* -
conclusion: nero 6.3.1.10 sucks. my burner works with the Ulead Burn.Now. Any other burning program I should try/use?
Video Causing Computer to Freeze
By Ownaholic in forum Software PlayingReplies: 4Last Post: 26th Apr 2012, 13:10 -
DirecTV DVR: how do I get to my computer to record to DVD?
By hyphenate in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Dec 2009, 10:54 -
Pioneer DVD Recorder still has picture freeze DVR-450H model
By marionr26 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 5th Oct 2009, 18:03 -
Can you read DVD's from DVR's on the computer?
By feeman_4_life in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Sep 2007, 03:34 -
my computer freeze all the time
By ieh4f in forum ComputerReplies: 13Last Post: 24th May 2007, 12:50
