recently i have been looking through the threads similar to this one and i have found none that answer my question. My problem is that i have been using the program iuVCR (since virtualdub seems to choke on winxp and this is the only alternative that can take it.) it all seems to go well.. i configure everything.. but then the captured avi has no sound where the preview did. i have selected line as the capture device as i did before with no problems. any advice at all is greatly appreciated.
Carl
It is better to be hated for what you are, than to be loved for what you are not...
-Someone once said that -
ps: the codec i am using is the PicVideo MJpeg codec at quality setting 18.. if this makes any difference.
thanks -
Make sure you use the audiosel.exe file off of the cd. You have to do that in win2k and XP to make audio work right each time you capture
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 17:13 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 16:22 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 01:10 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21
