I just upgraded to Nero 6.3.1.10 (from 5 something), and now my CD's burn at 24-32x with my Plextor Premium 52x, where before they burned usually at 52x or sometimes 40x depending on the CD. Im using the same exact CD batch. Anyone else have this issue?
Not that same issue, but it started to hang before the burn was finished. Sometimes at 5%, sometimes at 95%
The burner busy light would stay on, the status bar for Nero wouldn't change, but at a glance it would look just like it was burning, and the green indicator was lit.
Plus I didn't like the Fisher Price interface on Nero 6.
Going back to 5.5.9.14 solved the problem. They'll have to drag me away from my PC kicking and screaming before I let anyone put Nero 6 back on it :P -
Get rid of that junk OS XP and you will have sucess.
Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live! -
I have two machines at home, both running Win2K, both hung the same way while burning. XP is not the fault .....it's Nero 6. :POriginally Posted by Jah_Rankin
Somebody has an axe to grind.Originally Posted by Jah_Rankin
I'm sorry all of you XP fans, but the truth of the matter is that is junk all the way, Not Nero.
PRO slower ???
By cgp in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 12th Jan 2011, 10:49 -
Update to a newer version
By awhirr in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 25th Oct 2010, 15:19 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
May need newer software
By codeman in forum Newbie / General discussionsReplies: 2Last Post: 14th Nov 2008, 09:29 -
Newer Binaries?
By theorik in forum ffmpegX general discussionReplies: 0Last Post: 30th Sep 2008, 03:39
