Anyone have any experience with these drives. G4 loaded with ram running panther X.3.3. Reads CD's fine but will not recognize blanks. Asks you to name the disk then spits them out saying the drive is not supported. Thanks in advance, Wayne.
If the Thunder don't get you,
the Lighting will. -
Try using Roxio Toast instead of the Finder to burn DVDs.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Oh WiseWeasel, you are most knowledgeable. Right on, thanks for you help.
the Lighting will.
External Hard Drives
By mccoady in forum ComputerReplies: 10Last Post: 20th Apr 2009, 17:31 -
NAS or just regular external drives?
By sdsumike619 in forum ComputerReplies: 3Last Post: 4th Dec 2008, 06:56 -
TB External Hard Drives
By KayAt in forum ComputerReplies: 2Last Post: 29th Nov 2008, 08:54 -
Multiple External Hard Drives
By robjv1 in forum ComputerReplies: 1Last Post: 5th Sep 2008, 17:36 -
Need some advice on external hard drives
By VEBouto in forum ComputerReplies: 12Last Post: 9th Mar 2008, 17:36
