I have been trying to convert DVD movies to AVI files. I have been using moves that are 5+gig on the DVD each about 2hours in length. I have been using DVD2AVI. I am using divx high-motion and low-motion codec (sorry I dont have specific versions). I have experimented with bitrates between 4500 and 6000 (the max). The resulting AVI always comes out at around 2+gig in size.
Anyways what tool(s) whould I be using and what settings and codec for converting DVD to AVI, at best quality while keeping the divx/avi file size at around 700mb in size?
Patrick
Well, after ripping, make a AviSynth script to open all the VOBs and play the script in Virtual Dub mod while saving to AVI.
Hello. -
A good package to do this is the user-friendly AutoGK. If you're feeling brave (and have some more experience) you can try the full-blown Gordian Knot. For accurate filesizes, use two passes.
It's essentially a GUI for what Tommyknocker has suggested.
Cobra -
wow, reviewing the website for AutoGK, and reviewing the tutorial page, it just seems too simple. Rip the VOBs to disk, point AutoGK to the files, select output file, select output size - in my case 700mb so 1-disk - , select audio and let it go? and it will then create a xvid or divx of 700mb, give or take?
and that is without getting into any advanced features.
http://len0xmirror1.serveftp.net/~len0x/tutorial/AutoGK.html
Patrick -
What I usually do is set it to 695MB, and it usually hits that target size to within 500kb using two-pass with DivX. It really is a dead simple package to use.
If you find it hasn't got enough features or control, you can try the full Gordian Knot which I use - it's very feature-rich but not very friendly to the newer user.
Cobra -
Get Fairuse Wizard. Easier than all the rest.
Cheers, Jim
My DVDLab Guides
How to burn AVI to DVD without converting
By ss4nemis in forum Newbie / General discussionsReplies: 16Last Post: 19th Nov 2012, 20:43 -
Converting from DVD to Avi with Handbrake ¿Not again?
By luisppk in forum Video ConversionReplies: 7Last Post: 11th Jan 2012, 23:14 -
Converting AVI to DVD
By PhaedraUK in forum ffmpegX general discussionReplies: 10Last Post: 7th Jan 2008, 08:15 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting .mov or .avi to DVD
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 6th Jun 2007, 23:56
