i use my dvd player for kvcd and the thing start choking if there is too much action going on, its some kind of cybex. has anyone had this sort of problem with a cheapo dvd player and found a solution
It sounds like the higher bitrate needed for the high action scenes might be going past what the player is capable. Since this is not a spec VCD, try lowering the max bitrate.
what is a good dvd player that has a fast enough processor to play anything i throw at it
Since you are trying to play KVCD's, which are completely outside of any sort of VCD standard, there's really no guarantee that a given DVD player will be able to play it....unless you take one of your discs and test it. Take a disc down to your local "Big Electronic's Bargain Bin" and do some testing. Happy hunting.
PS, it's not necessarily the speed of the processor that's making it choke, it's all in the design."Art is making something out of nothing and selling it." - Frank Zappa
Media Player Classic suddenly extremely slow menu
By brucend75 in forum Software PlayingReplies: 6Last Post: 30th Dec 2011, 21:56 -
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
Need MTS Player with Slow Motion
By mightyjak in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 08:47 -
Trying to convert WMV to MPEG1 on a slow processor
By Gooey in forum Video ConversionReplies: 2Last Post: 21st May 2007, 03:59
