I have this video which has some kind of security in it that prevents me from clicking somewhere in the movie timeline, so prevents me from forwarding.
Is there a way to break this thing?
Results 1 to 9 of 9
- This is a war and we are soldier, but what if tommorow the war could be over? Isn't that worth fighting for? Isn't that worth dying for ? -
You can rip with Decrypter with the 'Remove PUO's' box checked in Settings, then reburn.
Where can I get Decrypter? 'cause its not easy to search by a program that's named 'decrypter'
- This is a war and we are soldier, but what if tommorow the war could be over? Isn't that worth fighting for? Isn't that worth dying for ? - -
if you mean dvd decrypter, how do I load a file in it? cause it's not a dvd or something
What kind of video is it? Mpeg files, DVD files?
If it's DVD files on your hard drive then you can still use Decrypter. First you need to make an ISO image- use ImgTool to make this.
Then use Daemon Tools to mount the image and open the virtual drive with Decrypter. -
It's an avi which is Divx encoded
Guess I can't help you then. I've had that happen trying to play mpg-2 files on Power DVD, but I never tried to fix it since it's not a problem once the files on in DVD format.
Try installing/updating FFDShow and/or use another media player>
VLC (videolan...bloody useful anyway)
Zoomplayer (...bloody useful anyway)
mpc (well... why not...comes in handy)
BSPlayer (well..)
Also dload Gspot or AVIcodec (and point at the file) and FourCC Changer
(all from TOOLS section).
Forward and rewind functions are choppy in H264 video, please help
By ejai in forum Video ConversionReplies: 4Last Post: 24th Aug 2011, 14:54 -
Why is this happening?!?!?! Video plays in fast forward motion.
By pcdoctor2 in forum EditingReplies: 13Last Post: 22nd Jun 2010, 05:54 -
Canīt do a scan forward without messing the video
By dexter30 in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 07:56 -
Video stucked when fast-forward
By dk2000 in forum Capturing and VCRReplies: 2Last Post: 23rd Jan 2008, 09:08 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48
