On a DMR-HS2, I have edited out commercial breaks frame-perfect on the HD, and the program plays back perfectly from the HD.
I have then transferred the program to DVD-RAM using high-speed dubbing, and imported the .VRO file on a PC using TMPG DVD Author, but the edits are slightly inaccurate (there are a few frames still present which I had edited out).
I have also noticed that when using markers with partial erase, skipping to the point at which the marker is set is not always accurate. Could this be connected to the above?
accual cuts are most likely on I frames only ..
in preview, its just skipping those parts you cut out .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you want frame-exact edits, it might be better to leave the adverts in before you go to DVD-RAM. Then they'll be easier to locate after you've transferred to the PC for editing. TmpgEncDVDAuthor isn't that accurate either (probably the same I-frame issue that BJ_M mentioned). I tend to use Womble Mpeg VCR when I need to precisely trim and cut mpeg video.
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
