I have a problem dubbing in the "DVD-R to HDD" direction on my E80H. When I select this direction, I cannot arrow down to the "Select Material" box or the "Start Dubbing" button. All I can do is toggle the direction button or press "Return" to leave this screen menu. No problem dubbing in the "HDD to DVD-R" direction. Any suggestions?
Thanks, Eric M
I could be wrong but I believe you can only record from DVD-Ram to HDD. Check page 15 of your owne's manual and it should explain this. I have read about people looping the outputs of the unit to the inputs of the unit and recording that way but I haven't tried it myself.
JCWBobC: I appreciate the reply. The E80H has a dubbing direction button which toggles between "HDD to DVD-R" and "DVD-R to HDD". What I'm trying to do is record back onto the HDD the shows I previously burned onto a DVD from the HDD on my E80H. Are you thinking that I should "RECORD" the shows back to HDD and then reburn them to another disk? Thanks, Eric M
Eric, only DVD-RAM discs can be dubbed back to the HDD on the E-80. To dub back DVDR discs you'd need to upgrade to the E-85. Other methods for you to get the footage back onto your E-80 are by dubbing the source material back once again to the HDD, playing the existing DVDR back on another DVD player and recording to the E-80's HDD, or the cable looping trick which has already been mentioned in regard to this unit.
What exactly is rotten in Denmark? -
Here is a simple solution to your problem that I have done before.1-hook up the audio cables and video cables from the out put jack and make a loop and hook it up to the L1 jack in the front of the dvd recorder and dub from dvd-r to hdd that way and thats it ,2-If you want to see what you are doing just hook up your component video cables to your tv set and use 2 Y adapters with one going to your tv and the second to the L1 inputs in front of the dvd recorder and your all done easy!!!
I've heard of this looping trick many times. I decided to try it last night and only got static on my recording when I went to play back. I looped it from the output of the unit to the L2 on the front of the unit. Do I need to set my input to L2 for it to be able to record? Also, is there a quality loss when dubbing from DVD-R back to the harddrive?
Tider -
There is a trcik you can take the MPEG2 file from DVD-R with TMPG and put the mpeg2 file on DVD-RAM they talk about this at www.dazzlegeek.com
Direction for software
By JohnCrewdson in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 14:17 -
Problem: No dubbing from Sony HD camcorder to hard drive of HDD
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Feb 2010, 22:43 -
4:2:0 - more than one type of Cb Cr sampling direction ?
By Movie-Maker in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2008, 16:45 -
Panasonic DMR E80H problem when recording..
By Gravelexpress in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th May 2008, 09:36 -
Encoding in reverse direction
By Someguy2 in forum EditingReplies: 8Last Post: 15th Jan 2008, 05:49
