Results 1 to 12 of 12
  1. i tried to make a back up of the truman show. i used dvd decrypter but i try to burn it won't work. i get the following.
    i also get an error using dvd clone
    ain't no black
  2. You forgot the menu.
    Oct 2002
    I need a slight bit more information on this (can't be too specific on the details cause I don't know the disc), but it appears that you need to change your rip settings in DVD Decrypter from ifo to file mode, you seem to only have the main movie files, and you need the entire disc. If the movie is too big when you rip the entire disc in file mode then you have some options whether to reencode, transcode, strip out the unwanted stuff, doesn't matter that is all up to you and the amount of time you want to spend, but you need get the entire disc before you start the ball rolling.
    Jan 2002
    Not the end of the world!
    Use DVD Shrink (freeware) and use ReAuthor mode to get just the movie only. You tried to rip "movie only" on DVD Decrypter and that does not make DVD Compliant files. What you tried can work, you just left out some steps.
    Oct 2002
    Shrink, I should've thought of that, just make sure you select "no compression" on your reauthor.
  6. could i not just add the vob files and have the dvd play the film and nothing else?
    ain't no black
  7. Nope.
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  8. i can't open it with dvd shrinker. is there nothing i can do with the files then?
    ain't no black
  9. You could use DVD Fab or IFO Edit to recreate the missing navigation files.
    You could run DVD2One through - that would do pretty much the same.
    Or you could rip your original DVD again with DVD Shrink
  10. Now I hope he didn't go to McDonalds and rent the movie for $1.00 and try to copy it? That's right the magic word is "Back-up"
  11. Just intervideo dvdcopy with anydvd. Put DVD in click copy and you got a back up on 1 DVDr in 25 min. All menues all extras.
