I have ripped LOTR3 and used dvd2avia nd got a wav file 3hours+. No audio program can open it? Any suggestions?
Results 1 to 9 of 9
Which audio stream did you rip? AC3? DTS? Do you have the proper decoders installed on your system?
yes. its all waves above 3 hours. cant convert or anything
why the heck you rip ac3 (no dts on LoTR 3) to wave file -- 3+ hours of wav files going to be HUGE !!!
ot did you rip as ac3 ? then you need a ac3 codec ..
what are you trying to do anyway ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i need it to be wave to load it into tmpgenc
Why not use DVD Shrink 3.1. I have backed up LOTR3 and it is beautiful.
DVD Shrink --> Re-Author, No Menus, No Spanish, Audio Ch 1 only. fills the DVD and compresses about 50%. Works great. -
yeah sounds like you might be doing things the hard way. DVDShrink will give it to you in a neat little ready to burn package. If you want to extract sound clips or peices from it I would highly suggest womble mpeg video editor. Amazingly easy to use and almost NO processing time if you keep the video in the same format/bitrate.
India becomes the king of the spammers
By Bonie81 in forum ComputerReplies: 0Last Post: 25th Apr 2012, 16:51 -
The King of Queens meets The Terminator?
By takearushfan in forum Off topicReplies: 0Last Post: 21st Jan 2011, 18:05 -
Mini DV is the king
By jazu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th May 2009, 09:43 -
What is the deal with the f**king windowboxing?!?!?!
By explosionfoot in forum ffmpegX general discussionReplies: 9Last Post: 20th Apr 2009, 13:25
