Will PC read Panny E50 DVD-RAM?
if so what dvd drive do i need?
Results 1 to 14 of 14
The E-50 doesn't record to DVD-RW, it does record to DVD-R and DVD-RAM. To read or play DVD-R on a computer all you need is any DVD drive to read DVD-RAM you will need a DVD drive that also reads DVD-RAM.
I bought a toshiba one, cant remember model number. Go search around youll find some DVD-ROM drives will read DVD RAM. You can get em real cheap.
LF- D521
Might surprise you but panasonic makes computer DVD-RAM drives too.
That model reads carts. Also, computer ones require a DVD-RAM driver to be put on & your unit comes with that. -
Does the Panasonic E50 DVD-RAM record the video to a standard DVD format when a DVD-Ram is used?
Toshiba SD-M1502 and up can read DVD-Ram. -
DVD-ROM drives that read DVD-RAM:Originally Posted by kel
LG GRD-8162B
Toshiba SD-M1712 (not the new SD-M1802, they've removed DVD-RAM support from this one)
Samsung SD-816B -
Many ioMega and Hitachi (same mechanism) dvd-writers are able to read and write dvd-ram, maybe readers too.
No, it's different than the standard DVD-video format. The file format is .VRO instead of VOB and there's only one big one instead of the standard 1 GB VOB file size limit. Won't play in a standard DVD player.Originally Posted by gastorgrab"Art is making something out of nothing and selling it." - Frank Zappa
LG dvd burner is the besy to read DVD-RAM you can get one at www.newegg.com
"No, it's different than the standard DVD-video format. The file format is .VRO instead of VOB"
Yeah, but there are tons of posts here on how to get them to convert to a regular dvd format.
Dvd-r are cheap now, so no reason to really use dvdram if you want to edit it later on the pc.
I have a lf-d521 & it takes carts too, most dvdram writers wont take carts, so check that too. ebay.com should have plenty of dvdram writers. -
I just ordered the LG GSA-4081BI from http://www.directron.com on sale for $84 with free shipping. From the site:Originally Posted by kel
Features: All Format Writing/Reading DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, CD-R, CD-RW. 2MB Buffer with Superlink Buffer Underrun Error Protection. Convenient E-IDE/ATAPI Plug and Play Interface. High speed Media Support. Maximum Write Speed: 8x DVD+R, 4x DVD-R, 4x DVD+RW, 2x DVD-RW, 3x DVD-RAM, 24x CD-R, 16x CD-RW. MPC-III Compliant.
Because I have a Panasonic E85 I wanted the DVD-RAM capability and the price seemed good. I read a review that was generally good. I should receive it by the end of the week. If you want to wait I'll post a review. My time is limited so it might be a few days after I receive it. Let me know.[/i][/b] -
Nu Tech drives are also good options for reading DVD-RAM.
http://www.nuniverse.com
SD Panny Plasma Quality worry
By MAC007 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Jan 2011, 15:08 -
I want to panny bd60 or jvc xvpb1
By atom1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Aug 2009, 10:51 -
panny lx3 movie
By charlietoosey in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2008, 05:22 -
Bad burn - Panny E30 or TY disc?
By jdachik in forum MediaReplies: 5Last Post: 21st Jul 2007, 11:42 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
