I have about 25 videos of horse races, all in mpg format, all captured in streaming format from the web, and all very low res. If I burn them to a DVD it plays them full screen and they are very grainy.
Is there any way to set up the DVD to play the video in say, the upper right hand corner of the screen, taking up about 2/3rds of the total screen, leaving the left side and entire bottom for text such as the horse's name, date of the race, jockey, etc? I'll play with the "window" size till it looks acceptable on the TV.
Ideas? Know of a software package that can do this?
The only way to do this and be certain it would work would be to overlay the video on a fullscreen black background so it appears with large black borders all the way around. You should be able to do this is an any good editing program (Vegas, Premiere etc.) or compositor (After Effects, Combustion, Fusion etc.). This way you can be sure it will work on an TV.
If you use a compositor, you can also add the text at the same time, and add some fancy graphics to spruce it up a bit.
how to make a video "stickin" to a certain view (frame)?
By Srivas in forum EditingReplies: 17Last Post: 14th Jan 2012, 09:11 -
"Full Screen" button not working properly
By ironjack in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 19:20 -
Video "doubled" on Avidemux's work screen?
By gastrof in forum DVD RippingReplies: 1Last Post: 26th Jan 2010, 11:19 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 05:08
