When I am capturing from my camara the computer accepts data for about 10 mins and then converts the data. After it is done converting the data the computer gives me an error message that the captured data exeeds the capacity of the HDD. I have approximately 30 G of available space. Is this enough space?
I am using a Sony mini dv camera recorder. I am using Imagemixer ver. 1.5 forn Sony to capture the video.
Thanks for any help.
I assume you are doing a "capture" via the FIREWIRE connection ... also known as IEEE 1394 as well as i.link
This should create a DV AVI file on your HDD that is approximately 13GB per hour.
So it sounds like you have enough space.
Maybe you could give us more details as to EXACTLY how you are doing it.
- John "FulciLives" Coleman
P.S.
Are you using the NTFS file system? This is available if you use WinXP and I think also Windows 2000"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Don't transfer the videos using USB, that will only give you shit quality. Use the iLink/Firewire transfer only.
Do check whether you're using FAT32 or NTFS. FAT32 has a file size limit of 4 GB (or was it 2 GB?), and this could be causing your errors. -
Well after hearing more details me thinks the problem is really the USB method of transfer.Originally Posted by pyrohydra
This is not the GOOD or PROPER way of transfering digital video to a computer.
@ELM3420
Like we both said you need to use FIREWIRE transfer.
Its 4GB. But I would doubt that is the problem. Even assuming DV video, 10 minutes would be in the range of 2 GB. Well below the limit. It may be the problem though, I would not discount it entirely because....Originally Posted by pyrohydra
I did a quick search about imagemixer and found that it requires 3 times the size of video in temporary HD space
If its a crappy program and tries to shove this in a single file... boom, you passed the FAT32 barrier.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
question about retrieving my HDD data? might be dead?
By NaHLiJ in forum ComputerReplies: 7Last Post: 28th Nov 2011, 09:01 -
windows 7 64bit and secondary data 3TB HDD not visible in full capacity
By deejay.2001 in forum ComputerReplies: 14Last Post: 21st Jun 2011, 16:08 -
Help! How to recover data from corrupted HDD?
By FulciLives in forum ComputerReplies: 63Last Post: 23rd Oct 2007, 10:31 -
Recovering data from a laptop HDD
By PhoneMatt in forum ComputerReplies: 9Last Post: 30th Sep 2007, 20:23 -
Data retrieval from a DVD HDD... HELP!
By onavlis99 in forum RestorationReplies: 3Last Post: 31st Jul 2007, 09:36
